budget brake upgrade
98 Z28 looking for more brake power. I replace lines with Russell stainless steel kit. I want to do the Z51 conversion but after reading decided that I should upgrade to larger rotors but keep my stock calipers for budget reasons, will this be possible. I thinking this set up will work minus the calipers
C5 conversion bracket-
GM Part #
12530682
12530683
10445856
10445857
12455799
22163727
12530697
12530703
22163795
10139097
GM Part #
Quantity
Description12530682
Right front caliper (standard C5)12530683
Left front caliper (standard C5)10445856
Right front rotor10445857
Left front rotor12455799
Pad abutment bracket22163727
Front caliper brake hose12530697
Pad abutment guide pin12530703
Guide pin boot22163795
Banjo bolt10139097
Banjo bolt copper washers
That looks like the Team Chevy list that is floating around here. Looks good, minus the caliper brackets and pads. I can't remember if you need longer brake lines for the LS1 though. You will also need 17" rims to clear the new brakes, unless you have them already.
I got 18 C6 wheels. I want to run the z06 rotor with my stock ls1 caliper. is this possible. also my friend tells me I only need the abutment brackets and the rotors, all the hardware is the same?
carguyshu
01-22-2017 11:19 AM
