Bump steer and rag joint question
Anyone using baer's bump steer for lowered cars. and aslo this aluminum rag joint from unbalenced engineering?http://www.unbalancedengineering.com/Camaro/
Any noticeable improvement in steering from the bump steer kit. I have also heard these kits wear out faster than the original equipment. Anyone have any problems?
The rag joint- is there any vibrations or any other problems going to this solid piece rather than the rubber?
Thanks in advance, Scott
Re: Bump steer and rag joint question
I have a rag joint eliminator and I am happy with it.
At highway speed no bothersome vibration comes through it.
I notice a little more up and down vibration in the wheel on hard bumps.
Not sure if that is the joint or not, I made a lot of other changes.
The shaft has 4 U-joints, no need for perfect alignment. The steering feels great.
If you have headers it makes more sense, the pipe run very close to where the rubber is.
ZBLKHELLRZR
08-18-2002 07:57 AM
