bushing advice
bushing advice
The majority of the bushings on my front end need to be replaced. I'm thinking I should go with poly bushings since they have been recomened to me by a number of people. But my question is, can someone recomend me to someplace that sells "bushing kits" or something that would have all of the bushings I need in one package? Thanks.
Re: bushing advice
Energy Suspension has a poly rebuild kit for the 4th Gen front ends. I know they include all the parts in the ES "Master Set", but that also includes the rear suspension components, tranny mount, etc. Don't know if they sell the front end kit seperately, but if you want the parts list for the front end componets, I can give it to you.
Re: bushing advice
I would love the parts list. I tried unsuccessfully to find it online. Also, thank you for the advice. Here's my email address if you need it. Colonel_kurtz_@hotmail.com
Re: bushing advice
Energy Suspension has a complete kit which includes: front and rear control arm bushings, front and rear sway bar bushings, front and rear end link set, torque arm mounts, rear panhard bar bushings, and tie rod end boots. The part number is 3.18130. Depending on were you purchase them from they will run around $170.00 on up. We are a energy suspension distributor but do not stock this paticular item. If you cannot find them let me know and I can see if they have them i stock.
Re: bushing advice
I already told him about the "Master Kit" in the post above... he needs the ES part #'s for the front end components only..... upper and lower A-arm bushings and front sway bar bushings and end links. I can get them when I go home from work today, but if you have them , maybe you could generate a sale
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
WobblySausage
10-07-2015 10:09 AM
