c5 brake conversion?
Old 06-22-2006, 08:45 PM
  #16
Aklaim's Avatar
Re: c5 brake conversion?
Originally Posted by SpeedDemon02SS
on the LS1 the rotor is 12.5 inches. the c5 is 12.75 inches. you can use the rotor, but you have to get a bracket for the LS1 caliper.
LS1 (fbody) rotors are 12" even. C5 rotors are a hair over 12.75"
Aklaim is offline
Old 06-23-2006, 03:44 AM
  #17
SpeedDemon02SS's Avatar
well how much is the bracket for the bigger rotor? as well as c5 calipers and pads?
SpeedDemon02SS is offline
Old 06-23-2006, 07:45 AM
  #18
gt_biker13's Avatar
Just the brackets are $240 from UMI http://www.umiperformance.com/2120.aspx
You dont need the calipers, but if you want them the set is $720 http://www.umiperformance.com/2120A1.aspx
gt_biker13 is offline
Old 06-23-2006, 08:16 AM
  #19
well, what is the point of doing the brackets if your not going to go with the calipers?
do the brackets keep the calipers in their stock location?
Old 06-23-2006, 09:56 AM
  #20
gt_biker13's Avatar
There’s no difference in clamping force between the calipers, you wont notice anything unless your driving is very hard (racing). The C5 caliper is pressure cast so it flexes less and its supposed to last longer. The purpose of the brackets is to move the caliper outwards to accommodate for the larger rotor.
Old 06-23-2006, 10:12 AM
  #21
But do the c5 calipers hold a bigger pad?
If the caliper is pretty much the same, I may go with the bigger rotor set up.
Old 06-23-2006, 10:49 AM
  #22
nfa
nfa's Avatar
Yes, they hold a bigger pad and opens you up to more pad choices than the LS1 capiler.
nfa is offline
Old 06-23-2006, 10:52 AM
  #23
but are the calipers themselves alot bigger? keep in mind...im really going for looks too. or should i just get the entire kit with calipers and all?
Is it worth spending the 250 to do this to just change rotors. what should i do with my stock sized Eradi Speed's? they only have 4500 miles on them.
would my old LS1 setup be worth somethign with new pads/rotors/painted calipers?
Old 06-30-2006, 07:56 AM
  #24
Is the C5 caliper bigger than the LS1? I know they hold bigger pads, but im talking about shere size.
Henson071
09-18-2015 04:01 PM
RallyRed701/2
07-27-2015 02:55 PM
Boss002
07-24-2015 10:47 AM
Quick Reply: c5 brake conversion?
