c5 brake kit vs. Baer track kit
Old 06-12-2006, 09:37 AM
  #16
Bud M's Avatar
Re: c5 brake kit vs. Baer track kit
Yeah, you are not likely to crack a drilled rotor in regular street use. I have Baer drilled rotors and they are not cracked.
Bud M is offline
Old 06-12-2006, 12:54 PM
  #17
CL21376's Avatar
Originally Posted by blackztpi
to be honest though, there's not much maintenence on any brake system. just typical stuff. plus, have u seen the prices for vete stuff recently? damn i canb get the track kit for 549 right now
Where can you get this for $549 at?
I've been researching the C5 v/s Baer upgrade since I put my car away for the winter. With 12 years/40K on my front brakes, its time for an upgrade to support future mods. My problem--if you could call it a problem--is that the C5 brakes wont fit the 17" ROH wheels used on the 93-94 Firehawks. The Baer kit seems like the next best bet, but I've been hesitant to drop the money on them. $549 would be the cheapest I've seen them...
So unless anyone else has any other ideas, Baer it is.....
CL21376 is offline
Old 06-12-2006, 02:49 PM
  #18
OBE1 95Z28's Avatar
Originally Posted by Bud M
Bracket flexing on Baer kits? Hard to beleive. My Baer kit came with pretty heavy steel brackets.
The brackets didn't flex, the calipers would spread under high loads. As I stated above, I believe Baer fixed this issue.
I'm happy with my Baer kit but if the C5 setup clears your rims, go the C5 route.
OBE1 95Z28 is offline
Old 06-12-2006, 09:42 PM
  #19
blackztpi's Avatar
texas speed has the bear track kit for 549 right now. i was just quoted 658 plus shipping fpr the c5 conversion kit with drilled and slotted rotors from Kore 3. does the track kit fit inside more wheels or something? from what i understand, the track kit used a slightly bigger rotor than the c5 conversion kit.
blackztpi is offline
Old 06-13-2006, 12:44 AM
  #20
Bud M's Avatar
Oh, yeah, I've heard about Baer's calipers spreading.
Bud M is offline
Old 06-17-2006, 09:24 PM
  #21
Severous01's Avatar
i did the c5 kit. no drilled rotors though...they'll crack. i know of about 6 guys who have cracked drilled rotors. the slotted will help wet performance. you should find a place to cut the rotors before you buy them. there's noone in this general area who will cut drilled or slotted rotors...so that means buying new ones when they warp...and you'll know when they warp too. it will vibrate horribly so and it also cracks pads. gm dealers sell 2 kinds of caliper kits...just the caliper, or a rebuilt kit that includes the abutment bracket and shims. just the brackets are about 50 bucks...plus the rebuilt kits are cheaper than the new calipers to begin with.
Severous01 is offline
Old 06-19-2006, 02:50 AM
  #22
NipNaZ28's Avatar
does kore 3 have a website to order the c5 kit, because under 700 bucks is pretty cheap and im looking to get a c5 kit in about a month or so
NipNaZ28 is offline
10-31-2016 11:09 AM
RUENUF
03-13-2016 03:39 PM
dbrockma
02-16-2015 02:56 PM
CARiD
02-09-2015 09:35 AM
slocody
02-10-2003 01:04 PM
Quick Reply: c5 brake kit vs. Baer track kit
