c5 brake upgrade
#16
Re: c5 brake upgrade
i already have ls brakes. and id rather not mess with the proportioning valve, so i can choose between 3 different calipers to adjust the brake bias. using ls1 calipers will move the bias forward, c6 calipers will keep it the same, and c5 calipers will move it back a bit. i wanted to know if anyone had any suggestions as to which would be ideal. if the stock bias is already good, ill just go with c6 calipers
#17
thats a good start. do you happen to know if your rear abs activates before your front channels normally? i must say, there is a bit more brake dive than ive seen before in the camaro. and moving he brake bias backwards does tend to reduce that. i thought it was just a quirk of the car
F'n1996Z28SS
08-23-2023 11:19 PM
carguyshu
01-22-2017 11:19 AM
