C5 caliper bolts torque to 125lbs ???
C5 caliper bolts torque to 125 ft lbs ???
Ok im about to install my c5 kit and i was looking at the torque spec on the install sheet.I ve found that the 14mm mounting bolt need 125lbs of torque
Is it true of maybe there is a mistype because i found 125 ft lbs is a lot?
Thank you
Thank you
Re: C5 caliper bolts torque to 125lbs ???
Originally Posted by Dave K
maybe 125 lb-in (not lb-ft).
There's no way those bolts should be torqued to 125 lb-ft.
CGM2010CAMARO
04-07-2015 07:44 PM
