C5 swap what lines do i need?
As the title said what flex line do i need? I work at napa and can get this job done for much less than i thought including new brackets, calipers w/ pads, and drilled and slotted rotors
Re: C5 swap what lines do i need?
You want the C5 front brake lines. I recommend stainless steel lines from www.stoptech.com though. Better pedal feel.
What brackets are you going to use?
Dan
Dan
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
