C5 wheels on a 95 z28 clearance issues.
After I out these wheels on I noticed the RR us rubbing against the chassis. Do I need to best in the chassis with a hammer to clearence it?
Sent from my VS910 4G using Tapatalk
Re: C5 wheels on a 95 z28 clearance issues.
I had minor rubbing in the undercoating of my car with the rear tires, and extremely minor rubbing up front under the plastic fender/shields.
I'm currently using spacers but one of these days I'm going to take the wheel off and take a BFH and flatten the undercoating.
Where exactly are your tires rubbing?
Btw, I've got 265/40/17 (front) and 295/35/18 (rear) if it helps.
Sent from my SCH-I800 using Tapatalk
If it was only rubbing on the right side, it may have been a problem of the chassis not being correctly centered over the rear axle assembly. That problem might have been solved with an adjustable panhard rod.
I use an Adj pan bar to center 315-35-17 rears on 17x11 ZR1 wheels. Close clearance but no rubs after equal adjustment. I also clearanced the inner fender in the front area. B.
10-31-2016 11:09 AM
ChrisFrez
11-30-2014 08:41 AM
