C6 Brakes?
#17
The C6 Z06 brakes have countless flaws, and from what the Corvette guys are saying, they don't stop worth a darn anyways. Just because one brake system has 6 piston calipers doesn't mean it will out stop a 2 piston caliper. I have ridden in another F-body with the Wilwood 6 piston caliper brake system with 13 inch rotors (same as mine) with the same pads, and my Baer Track 2 piston caliper out stops his hands down.
#18
No Im talking about the C5 Z06 brakes, you can get them setup for under 500 and I havent been gotten any brake fade. Im trying to compare pad size and rotor diameter to see if the baer setup has any clear cut advantage over the C5 setup. from what I can see its just $800 more....
#19
#21
Thats the conclusion I came to when I was doing my research. If you have the same piston diameter and pad then your getting the same clamping force. the only difference I wanted to know what the rotors but I thought they are both 13"? Can anyone justify the cost difference?
#23
Of course but keeping those variables constant there shouldnt be a difference. the vane design on the C5 setup is curved to pull air through and you can ge them cross drilled and slotted. what do the vanes look like on the Baer setup?
#24
The baer track system is excatly the same has the c5 brake kit.Caliper are the same and they also use the 1 pieces discs.The only thing that i could find in my search was that the c5 disc is 12.8" and the baer is 13".
The baer track-plus sytem is also the same has the c5 brake kit.Caliper are the same.The main difference in this kit is the 2 pieces rotor that the baer kit has.
From my standpoint they are the same minus .2" of disc but the c5 parts are available everywhere and are also very cheap.
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
#26
Like I said before, the C5 Z06 brake setup is essentially the same as the Baer "Track" system. The Baer Track system comes with the Baer 13 rotors as well as steel braded brake lines. The calipers themselves are the same size, however after seeing both in person, and having used mine for years now and comparing it to others with the C5 Z06 brakes, the Baer Track system is a little better in quality. Both will potentially stop the same assuming you step up the rotor, and lines the same as the Baer system. I just feel that the Baer system is of higher quality. Is it worth spending the extra $? Most will say "no", but with everything else in my car, I wanted the best.
#27
Right, but why would you assume that the Baer kit has all of those characteristics the same as the C5 Z06?
#28
Because they use the same/similar caliper "mouth" and anyone can get cross drilled and slotted rotors. theres only so much room between the pads, I dont think rotor thickness has as must to do with it as does the cooling capabilities. Ill take a thinner, less weight, better cooling rotor over a thicker one anyday.
#29
Look at NASCAR, and or Formula One rotors, they are plain rotors not X-drilled or slotted, they have massive air ducts to keep them cool, but they depend on the thickness of the rotors to stop.
#30
Well I guess it comes down the material properties. if you can sufficently cool a thinner rotor then you should get better performance out of it since it will be lighter yet maintain its rigidity. but Ill admit thicker is better for our applications since brake cooling ducts dont come standard.
How thick are the Baer rotors? and how thick are the C5's. and even if the Baer rotors are 13" does the caliper mount make use of that extra .2"? or does it sit the pad in the same position on the rotor as the C5's? If it does then your carriing around extra weight that isnt doing anything.
An i agree 100% the cross drilled does nothing for you performance wise. but vane design and slots do help out quite a bit
