C6 Brakes on LT1
C6 Brakes on LT1
I found a set of OEM C6 Corvette 12.8" rotors, dual piston calipers, pads, and hoses, and I've heard I can adapt them to fit my 1996 Camaro SS. From what I've found, I need to trim the front spindles and get adapter brackets for the calipers. I've seen many different brackets available, but what type is best? Also, do the rear rotors and calipers bolt on, or do I need special brackets or modifications to make it work? Any information would be greatly appreciated!
These are the only engineered and strength tested brackets on the market.
They are currently on special for $211.65 until the end of May 31st and can be found and read about more at the following link.
http://www.hotpart.com/index.php?p=show&id=177
If you want a set of instructions for them let me know and I will email them over to you so you know what you are getting into.
07-04-2005 05:00 PM
