Camber Plates on a T/A?
Hey guys,
I got a 97' T/A with the Eibach lowering springs. The springs gave me alot of camber in front, I was searching the boards looking to see if anyone had a similar problem and everyone seemed to just deal with it. Well I just spend around $400 on tires for the front and I don't want them to go to waste too soon. I was looking at Ground Control's website and found Camaro camber plates, I was wandering if anyone used these? and if these will also work on my T/A?
Re: Camber Plates on a T/A?
You should be fine on camber. It shouldn't be much more than -.5 degs. But if your reall worried about take to a Alingment shop and they can fix you up to stock specs again. If that is what you really want?
