can you install lca without air tools??
Old 04-09-2007, 07:58 PM
jamilz28's Avatar
i cant brake the bolts maybe it from the car still being on the ground.
has anyone here done it with hand tools??
jamilz28 is offline
Old 04-09-2007, 08:08 PM
nicks2ndZ's Avatar
yes you can do it with hand tools...your gonna need to put it on jack stands for leverage...and it would help if you sprayed the bolts with pb blaster in case they are rusted....put it on jackstands and support the rearend with a jack...if you go to installuniversity.com you can get a tutorial on how to change them down to all tools needed
nicks2ndZ is offline
Old 04-09-2007, 08:09 PM
mdacton's Avatar
only thing I have ever used is hand tools.....soak em with PB blaster and put your little heart into it .........jack it up too...
mdacton is offline
Old 04-09-2007, 08:12 PM
2001NBMZ28's Avatar
Put LCAs/PHR on my car with hand tools - had mine on a lift, don't think doing it on the ground is a good idea.
2001NBMZ28 is offline
Old 04-09-2007, 08:28 PM
Greed4Speed's Avatar
2 words: breaker bar
Greed4Speed is offline
Old 04-09-2007, 09:43 PM
jamilz28's Avatar
i did do my panhard bar by hand it was not to bad i didnt even use pb blaster or anything.
i will put it on ramps and use a breaker bar how much should a breaker bar cost?
or should i just use a metal pipe over the wrench so i can put it off easier
jamilz28 is offline
Old 04-10-2007, 07:16 AM
A good size, quality breaker bar should be in your toolbox. If you cheap out, you just make it harder on yourself. The right tool is worth every penny.
shoebox is offline
Old 04-10-2007, 07:55 AM
danhr's Avatar
I have yet to meet a bolt that can withstand the fury of a breaker bar and a 1" wrench.
danhr is offline
Old 04-10-2007, 11:54 AM
95firehawk's Avatar
+1
95firehawk is offline
Old 04-10-2007, 11:55 AM
jamilz28's Avatar
yea i will go to sears Thursday to get an good one
jamilz28 is offline
Old 04-10-2007, 02:24 PM
2000GTP's Avatar
Even with a breaker bar, I had some trouble breaking the old LCA bolts free. Some squirts of PB Blaster and a couple hours downtime, they came right apart.
2000GTP is offline
Old 04-10-2007, 03:31 PM
z28 justin's Avatar
When I did my LCA's, I used hand tools. I soaked the bolts with PB Blaster and let them soak. However, I still managed to break the bolts and had to borrow a saw to cut the old control arms out. It sucked
z28 justin is offline
Old 04-10-2007, 05:05 PM
LiENUS's Avatar
I don't believe you're going to be able to change the LCA on ramps seeing as how you need to remove the wheel and whatnot
LiENUS is offline
Old 04-10-2007, 11:42 PM
jamilz28's Avatar
i am using the ramps just when i am brake the bolts loose then i will just my jack stands.
jamilz28 is offline
Old 04-11-2007, 09:53 PM
jamilz28's Avatar
yep i bought a breaker bar and it just poped the bolts out like nothing
i was surprised
thanks for the help
jamilz28 is offline
Quick Reply: can you install lca without air tools??
