Can you turn the bottom of the front strut?
I'm just going to put my front springs and shocks in. I had the strut mounts transferred over by a shop.
So when I go to install them, when the strut mount is in the upper control arm, the bolt holes at the base of the strut to attach to the lower control arm are angled the opposite way.
Can I spin them 180 somehow?
When looking at the bottom of the shock, I was thinking about angle of the bolt hole mount relative to the angle of the a-arm. IIRC, you can spin it in the bottom bushing. Now if it was twisted to where the holes didn't lineup, then compressing the spring is really the only way to get it to twist. I had to do it around 3 or 4 times each side when doing mine.
I actually remembered when I first got the DMS springs on and the shop guy swapped everything - he turned the strut mounts that was as well.
It was a bit stiff at first but it does allow you to rotate it somewhat.
I tried re-angling the bushing at the bottom and that was definitely a no-go. Tried using 2 large screwdrivers in the bolt holes and that bushing didn't want to turn. Well I only applied enough pressure I was comfortable with in fear of damaging something.
Magenta_Hearts
03-29-2017 08:54 PM
10-31-2016 11:09 AM
Jibberish18
08-28-2002 12:46 PM
