Car lower on one side
Old 10-10-2004, 01:57 PM
Mick's Avatar
I was looking at my car one day and saw that it is lower on the passenger side. This looked very strange so i measured it and it is one inch lower on the passenger side. I was wondering if anyone knew of this problem and how it can be fixed.
I was thinking about buying new springs (i currently run stock springs) to see if that would fix this. Any help would be appreciated, Thanks.
Mick is offline
Old 10-10-2004, 05:33 PM
Red96Lt1's Avatar
Re: Car lower on one side
Stop hauling around fat people. Yeah, I would assume it's the springs, but and inch is alot of difference. See if someone else has some input.
Welcome to the board.
Red96Lt1 is offline
Old 10-10-2004, 05:43 PM
Mick's Avatar
Haha, it was like this when i got it... No fat people thanks....
Anyone else?
Mick is offline
Old 10-10-2004, 06:05 PM
Donohue96M6Z28's Avatar
i have the same problem, but i have an eibach prokit on my car, and one side looks lower then the other
Donohue96M6Z28 is offline
Old 10-10-2004, 06:14 PM
n2ceptor's Avatar
Its a common problem with 4-gen F-bodies....
n2ceptor is offline
Old 10-10-2004, 06:19 PM
Mick's Avatar
What causes it? is there a fix?
Mick is offline
Old 10-10-2004, 11:09 PM
RedRyder518's Avatar
I have the same problem as well with my Pro-kit. My drivers side seems to be higher than my passenger side.
RedRyder518 is offline
Old 10-12-2004, 04:21 AM
Moderator
AL SS590 M6's Avatar
Yeah measure it when your sitting in it. And yes I'm serious. Most f-bodies are driven solo so GM put a little bias into the suspension so that with a driver and no passenger the car will sit level for better handling. If everyone were to park there's on level ground and measure you'd find that they are all like that. I have 3 of them sitting at the house right now and they range form 1/2 tp 7/8" low on the right.
AL SS590 M6 is offline
Old 10-12-2004, 11:32 AM
Now how am I supposed to measure it when I am sitting in the car?
Kidding!
Old 10-13-2004, 03:40 AM
Moderator
Kidding!
Long arms and/or long measuring tape.
Old 10-13-2004, 07:23 PM
Vega's Avatar
I say check your springs.
Vega is offline
Old 10-14-2004, 12:07 AM
wbna0149's Avatar
Thats a whopper of a tale .
wbna0149 is offline
Old 10-14-2004, 06:07 PM
Mick's Avatar
actually, i just tried it and it goes from an inch difference to a cm difference. Thanks a lot for the help.
Mick is offline
Old 10-18-2004, 12:15 PM
firebird_fury's Avatar
Did anyone ever find a remedy for this problem? I just finished lowering my car this weekend and I noticed that the left side of the car is lower than the right. Perhaps it is the adjustable panhard rod? I adjusted the rod to zero but the car is still sitting this way. Any help?
firebird_fury is offline
Old 10-18-2004, 02:36 PM
LPEdave's Avatar
You can put a piece of high density plastic at the top of one rear spring to raise that side of the car up. The plastic is available in 1/2" and 1" sizes. That's what I did, works like a champ.
Dave
LPEdave is offline
Quick Reply: Car lower on one side
