car sits 3/4 inch lower on pass. front ( help?)
just bought the car a month ago. noticed it sat 3/4" to 1" lower on the passenger front, and it rubbed. it had eibach goldlines in it. just today had new hotchkis springs and new struts installed and is still leaning on that side. the lip of the wheel is scraped up so it looks like the previous owner hit a curb with it. what could this be? something bent? does anyone know someone i can call?
any input would be appreciated
Re: car sits 3/4 inch lower on pass. front ( help?)
I am having the same problem but the cause of mine is a bent unibody. took the front coilovers out last night and am trying to find some replacements etc. If i cant i may just through a 1/2" spacer on for now and do some more looking. Wanted to find some adjustable coilovers but they are very expensive. The whole front of the car sits too low i think.
Originally Posted by n2ceptor
Been discussed many times... Concensis is probably body flex I believe....
Originally Posted by noxiousz28
so what is a common difference between the two wheels? 1/2inch ?
mine is now sitting on level ground a 3/8 diff. between the front wheels.
Originally Posted by michigan2500hd
Sorry, didnt mean to jack your thread. i dont know what "normal" is between the two sides. Mine was measured from the unibody to the ground at 3/4" low pass. side. So if i measure at the fender it is worse. But here is something i just found on my car....the pass. side lower control arm is bent back and up a little. i think that might be a problem,lol. i had to really inpect it carefully with a light and the tire off.( i was removing the coilovers too) My buddy down the street knows these cars pretty well so i will have him look at it soon. good luck
