changed rear pads, now ebrake has no tension/doesnt work
i changed the rear pads on my t/a, now I need to pull the ebrake skyhigh for it to engage even the slightest. wtf did I do wrong and how do I fix? its sitting with one wheel off in the dark
![Mad](https://www.camaroz28.com/forums/images/smilies/mad.gif)
Re: changed rear pads, now ebrake has no tension/doesnt work
You compressed the caliper pistons when you installed the new pads; start the engine and pump the brake pedal several times to bring the pistons back into position. This should cure your e-brake issue.
07-04-2005 05:00 PM
