Changingn brakes
Changingn brakes
I just recently received my hawk hps brake pads for street use and I have the $29.99 rotors from kragens. They are oem specs. The rotors should be okay with the new brake pads correct? Or should I upgrade to better rotors so that it won't warp too early. Also when you guys change your brake pads do you put the blue stuff/spray on the back of the brake pad so it won't squeak? I'm gonna change the rotor/pad today and wanted your input. Thanks
Re: Changingn brakes
Hmm I didn't know that. Well I already have the rotors and brake pads. The rotors on my car are the original with 101,XXX. They could burn anytime if I was to wait and buy the LS1 setup. I might have to do the LS1 setup another time. Thank you for the info.
no problem. I bought my setup for 165 shipped and the pads were like new and the rotors were in excellent shape. All i did was clean and paint all the parts and slap them on. It was probably one of the best bang for the buck mod. Well not hp but drivers satisfaction.
