Chassis Lubrication?
Re: Chassis Lubrication?
My car has the nipples for filling on the tie rod ends. I don't believe the ends from the factory had these. I usually just shoot some grease in when i do an oil change. I believe the book says 6000 miles though.
https://www.mygmlink.com/main/US/en/gm/home
cool site that you can custiomize for your car. it has a maint. schedule and everything. I highly recommend registering.
Originally Posted by mojorisin
i think they all come with the nipples...mine has them too.
how often should i grease control arm bushings?
Also I asked this question awhile back, couldn't really find anything on the search - what stock suspension parts can be lubricated, my car has alot of squeaks and rattles....
I think newer camaros came with all the greasable fittings sealed so you don't have to worry about greasing them. So it is very likely that you dont have the nipples. If that was the case you wouldnt have them unless you replaced a certain part.
alliance12364
09-23-2015 12:40 PM
Richardan15
05-30-2015 08:36 AM
