Compression fittings on brake lines?
Re: Compression fittings on brake lines?
Yes. While they might seal for some time, it is illegal in many (all?) states. You would also be undertaking a huge liability if it were to fail. A flaring tool is cheap enough.
Brass compression fittings are for use with copper/brass tubing. The soft brass sleeve doesn't 'bite' into a steel line. I've seen SS compression fittings bite properly into a steel line. SS compression fittings are specialty fittings used in corrosive environments and are very expensive,strictly a industrial item.
10-31-2016 11:09 AM
01-23-2015 01:13 PM
kclarson
08-22-2002 04:04 PM
