convertible rollbar
convertible rollbar
i just went 13.5 in my vert and the spray is next so i need to get a rollbar in to pass tech.
im new to this rollbar stuff so where would i go to buy one? should i make my own? is there anyway i can still use the backseat after i install it? thanks!
Re: convertible rollbar
The Wolfe Racecraft bar seems to be the most popular.
http://www.wolferacecraft.com/Search...?CategoryID=20
i see 4, 5, and 6-point rollbars...is each rated for a certain 1/4 mile time? how fast can i go with each? can i still use the rear seats with the 6-pt? thanks again!
NHRA requires 5-point roll bar for convertibles running between 13.49 - 10.00-seconds. Below 10.00 (or over 135MPH), you need a full cage, certified and tagged by NHRA.
A 5-point consists of the 2 points for the hoop, 2 braces to the rear, and one brace on the drivers side going forward, between the driver's shoulder and elbow (2+2+1=5).
A 4-point will not be acceptable by NHRA under any circumstances. Adding the "sixth" point by placing a similar forward brace on the passenger side is OK. You can also add a diagonal brace from each side of the hoop to the floor, and that will make it an 8-point bar. But all you need to be NHRA legal is a 5-point.
You'll have to ask someone who owns a convertible about how usable the rear seat is, but it appears the Wolfe does not interfere with the seat. Keep in mind that a rear seat passenger might be exposed to hitting his/her head on the roll bar in a panic stop. Also keep in mind that the front seat passengers may be exposes to hitting their heads on the bar, when not wearing helmets.
Finally, NHRA also requires a 5-point harness. The ones you can buy, while rated by SFI to be fully capable of protecting you in a severe crash, are not DOT approved, and are (to be technically correct) not legal for street use. That requires that you keep your stock belts along with the 5-point harness.
NewsBot
09-14-2015 02:02 AM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
08-05-2015 08:35 AM
