cross drilled/slotted rotors?
i'm looking to get a set of these for my 96 lt1 with stock brake components. i was thinking of just picking up the gm performance parts versions but wondered if there are any other proven performers available for the stock disc setup.
anyone have any that they could comment on or possible recommendations?
Re: cross drilled/slotted rotors?
I run a crossdrilled and slotted rotor from Autozone (believe it or not) called Aimco Extremes.
I have about 20k on them now with no negative results, they look great with no cracking and zero warping.
I am not real hard on them though, no autocrossing or road racing just has to haul me down from 104 mph trap speeds.
They cost about 100 bucks each, stock size rotors and they look great behind my Pro Stars.
Something to look into if your not autoxing or road racing and just want the crossdrilled and slotted look and better than stock performance.
that's a good suggestions... $100 a piece thought that's only $100 total less then the baer rotors? would it be worth it to spend slightly more on a rotor from baer/wilwood?
WobblySausage
10-07-2015 10:09 AM
