CTS-V brakes?
#16
Re: CTS-V brakes?
Interesting.
If they bolt up the same as the C5 brakes and the offset would work out then you would still need to find a rotor that would work and be the correct diameter.
I should have said in my last post, "The CTS-V rotors are 14", so I doubt they'll work with C5 adaptor brackets as the calipers likely won't be offset enough".
I don't know this for a fact, if they would work then that would be cool.
#17
Re: CTS-V brakes?
Just read your quote over again.
The C5 rotors are like 12.8 inches in diameter. The CTS-V rotors I believe are 14".
I'd like to see how the guys who are running them with C5 adaptor brackets and rotors are doing it.
