Drilled/Slotted Rotors for street
#61
Re: Drilled/Slotted Rotors for street
Originally Posted by RussStang
Did you not read any of what we talked about? Modern brakes do not outgas to any serious degree, even in racing conditions. X-Drilled rotors are worthless besides cosmetic, although the jury still seems to be out for slotted.
#62
Originally Posted by niceroc
yes i read... and those pople might have been mis-informed just as well as i might have been... but in most racing appilcations i have seen slotted rotors... so im going to believe what ive seen and read...
Cross drilled rotors were designed to help gases escape the rotor, but seeing as pads dont have this problem anymore, have long since outweighed their usefulness as far as performance goes.
#63
Slotted rotors are not designed to vent brake gases. Slotted rotors are designed to keep the brake pads from glazing over, and to provide a channel for brake dust to escape.
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
Cross drilled rotors were designed to help gases escape the rotor, but seeing as pads dont have this problem anymore.
....and im not trying to seem condesinding about this...
#64
where'd u hear that?![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
it may not be a problem on the street but why do racers still use them? and how do the holes vent gases any differently then a slot would?
I know a lot of the really high end racing teams use carbon ceramic brakes, and I don't think they run anything but a flat surface on the rotor at all.
#65
Roc,
Go to pad manufacturer websites instead of rotor manufacturers and read. Modern pad materials do NOT have out gassing problems. If you don't believe us, then do yourself a favor and check out some of the roadracing or auto-x based boards.
The rotor manufacturers are saying all this to get more of your $. Its like the spark plug companies making all these designer elctrodes that cost $6/ea when regular copper plug work great at under $2/ea. Splitfire says their plugs will make more power, do you believe them too?
#67
[QUOTE=RussStang]
Show me a professional race team that still uses cross drilled rotors. I would really like to see this. Slots are not designed to vent gas. Look at the picture of the CTSV-R a few posts up. The car is running slotted brakes, but no cross drills to be seen.QUOTE]
have you ever heard of ferrari? lamborghini? porsche?....... FORMULA 1?
#68
Originally Posted by toby360
Sounds like its working quite well too ![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
#69
Theirs is a whole different class of braking. Their brake system alone is probably worth more than your car. F1 engine also spin to 20k RPM does this mean your needs to also?
#70
I know for damn sure that Formula 1 does not use cross drilled rotors.
#71
http://racing.jbskyline.net/2001/Gal...der/Bild51.php
http://www.billzilla.org/BRAKE.jpg
http://www.atspeedimages.com/scca_au...ont_brakes.jpg
http://www.zetecinside.com/xr2/pictu...ont_brakes.jpg
http://www.mogsport.co.uk/images/venteddiscs.jpg
http://www.lynxmotors.co.uk/grafix/456.jpg
theres olny a couiple i found in a few mintues...
#72
Ok. I have no idea why you showed me the pictures of the slotted rotors, because I have said all along that there may be some merit to them, so it is beyond me why you are trying to prove to me those are on race cars.
My only question about the drilled rotor cars; what kind of race cars are they on, and how old are the pictures?
#73
http://www.billzilla.org/fraser.htm
is the page http://www.billzilla.org/BRAKE.jpg is from. The guys just doing this as a hobby on his own personal project car (in new Zealand too
http://www.mogsport.co.uk/brake.htm
is where:
is from, here theyre talking about dinosaurs 1960's racecars. Secondly they sell brake services/upgrades. Nothing about any modern race car using cross drilled rotors. Mainly just a picture to show they service brakes more than anything.
The rest are all slotted... as pointed out above that slotting does have its purposes. But finding slotted/crossdrilled racing rotors being used to doesn't seem to be an easy task![Big Grin](https://www.camaroz28.com/forums/images/smilies/biggrin.gif)
http://www.sae.org/servlets/productD...D=2006-01-0691
from jon's post above.
is where:
