drivers restraint system question for 11.499-
i seen the revised ruling saying a driver who is faster than 11.499 must have a restraint system, (im assuming 5 point) but does it need to be on/thru a racing seat? i would like to rig one up to a cage but keep the stock power seat.
I don't think this is any sort of major change... anywhere I raced, you needed the roll bar to run under 11.5 and if you had to have a roll bar, you had to have a 5-point 3"-wide harness. I think the NHRA language that was posted as a change on the "Drag Racing...." forum was specific to the "Stock" class, where previously, the requirement for a roll bar was defined by the class the car ran in (A/S thru M/S) and not by the car's ET. As the cars got faster, then needed to change it to an ET based rule.
You can run a harness with a stock seat, as long as everything else meets the rules.
The harness has to attach to the cross-bar no more than 4" below the shoulders. Works OK with a Firebird seat with the separate headrest, but there may be a problem getting the harness straps over your shoulders and keeping them there with the Camaro seats and their integrated headrests. A buddy of mine had his stock Camaro seats modified to allow the harness to pass through at shoulder level... a single hole cut and edged in his white leather 30th SS seats. He ran in the 9's with a full cage with that setup. With my Formula, they never had a problem with the straps run between the seat back and the headrest.
http://www.injuneer.com/images/photo...r/DCP02778.jpg
With a racing seat, the crotch strap must be anchored to the floor behind the chest line. With a stock seat, they will allow you to pass the strap in front of the seat, and not through it.
With a racing seat, the seat must be bolted to the cross-bar, with a stock seat it isn't required.
With a racing seat, the fore-aft slider has to have an NHRA approved double latching mechanism. With a stock sear, it isn't required.
http://www.ultrashieldrace.com/prod.php?id=34
These are great restraints with nice, padded sternum protection.
They are SFI rated and reasonably priced at ~$200 for a 5 point.
If i remember correctly a car slower then 9.99 doesn't need up to date seat belts. If thats the case look for a used set on ebay or what not. save yourself a few bucks. we liquidate ours on there every 2 years it might help you out.
ill go that route. thanx. the one thing i wasnt clear on in your write-up was the crotch belt on stock seats. does that loop back to the cros member (the female end) or get bolted to floor?
The Stroud's are the same. The strenum strap is already attached. The sternum strap on the Stroud's isn't quite as nice as the Ultrashield (it's not padded)but the belts are slightly less expensive at around $155
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
07-04-2005 05:00 PM
