Driveshaft Loop
![Question](https://www.camaroz28.com/forums/images/icons/icon5.gif)
I need to install an aftermarket driveshaft loop because my TSP y-pipe bangs and scrapes my stock one with 4 bolts bad.
Is there any aftermarket loop that can be installed without removing the driveshaft? Maybe one where the top of the loop comes off to fit around the driveshaft and is held on by two bolts?
Re: Driveshaft Loop
Spohn sells a driveshaft loop that dosn't require you to remove the driveshaft. Not sure if it will provide the clearance you need for the y-pipe though. The BMR loop has a bend in it to clear the y-pipe, but it requires you to remove the driveshaft to install. Which really isn't a big deal. 4 small bolts hold it in and then it'll slide out. Install the loop and then slide it back in and bolt it up.
tdigger9899
09-07-2015 10:56 AM
