drums to discs on 10 bolt rear
http://www.angelfire.com/hiphop/doug...isc_brakes.jpg
these are the disc brakes i want. i got a 10 bolt rear. its currently drums. i havent ever converted to disc however. from what you see there is that everything you need? i thought i would need a mount to hold the rotors? am i wrong? or does is the hub the same from the rear drums? does the brake booster and master cylinder not need to be changed out? i always thought you had to?
thanks so much for all the help
Douglas
Douglas
Re: drums to discs on 10 bolt rear
Link not working. Anyway, it maybe cheaper to buy a 10 bolt with brakes already on it. For a 4th gen I know they go for like $200 used. They are pretty weak and nobody seems to want them. With an M6 and Slicks they go Boom!
yeah but if it goes "boomb" you cna change out the gears in the rearend for stronger gears no? im not to knowledgeable in the camaro reend. thanks for the fast reply
Douglas
Douglas
