DS safety loop clearance problems
![Unhappy](https://www.camaroz28.com/forums/images/icons/icon9.gif)
>I have a clearance problem ... ![Frown](https://www.camaroz28.com/forums/images/smilies/frown.gif)
I have all BMR componets i.e.- boxed subframe connectors , and TrakPak , but the drive shaft safety loop will not fit with the TrakPak .
Has anyone else have this problem and if so what did you do
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
will not fit?
how so? I assume that you mean it wont line up with the bolts for the cross brace.
the only reason I can see it not fitting is if it was drilled wrong, or your chasis is bent a bit.
>The way the TrakPak torque arm is designed ... it has clearance problems (see link) http://www.bmrfabrication.com/instru.../conv-rear.jpg
even their site tells you this .
I'm confused... BMR tells you on the website:
".....will not fit with BMR Trak Pak."
....and you want to make it fit? Why not ask BMR what DS loop they recommend with the Trak Pak?
you get confused that easily
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
Originally posted by bowtiepwr
>way ahead of you ... just have to wait for their response , but I was hoping that someone else had close to the same situation .
Sorry to inconvenience you. Have a nice day.
I was just trying to help you get an answer.... since I seem to have offended you in some way, next time I'll mind my own business when you ask a question.
you ddn't offend me I was just being goofy (didn't you notice the "
I applaud your drive to answer all the posts especially ones that are as trivial as mine .
01-23-2015 01:13 PM
centric
08-15-2002 09:04 PM
