E-brake not working
E-brake not working
Ok, so my ebrake hasnt been working for a while, so i put it up on my hoist and noticed that one of the cables coming from the rear passenger side brake was broken off the divider. So i put it back on, no problems, and now there is still nothing with the handle? You can pull it up with no resistance, any ideas? Thanks for the help, Greg
Re: E-brake not working
Theres an intermediate wire that wraps around the parking brake assemby, goes through the floarboard, and connects to another wire.
You need to find out if that is the wire to replace or the one that it connects too which leads to the wheel.
turns out everything is ok from the lever to the brakes. Nothing is seized or loose. its all tight. Is there something that im missing on the brakes? It worked totaly fine then once day it just stopped? any ideas?
Sounds to me like one of the cables is broken inside the sheath; midway between the tranny and diff above the drive shaft is the yoke and you can pull on each cable end and see if they are still solid. There also is a e-brake travel adjustment http://shbox.com/1/adjparkingbrake.jpg
Yea i pulled on both cables and they are both tight? I dont understand why all of a sudden it stopped? Maybe i should just adjust it and see i guess. hopefully not smoke out the rear brakes.
squarehead
01-15-2015 07:02 PM
