Eibach and Koni's
Eibach and Koni's
Just installed Eibach Prosprings and Koni's sport shocks from tire rack on my 02 TTop Z
Not happy, getting major bottoming out front and rear...........
Anybody have any ideas or experience with this setup?
Re: Eibach and Koni's
If you have the LS1 pro-kit the spring rate are too soft, and as stated above what perch is the lower spring seat on in the front? It needs to be on the upper snap-ring grove position. IMO get a set of Vogtland , or if you budget/time permits a set of strano lowering springs, also made by Vogtland.
