Eibach Progressive springs
Can anyone post their car with pictures with the springs.
I'm thinking about putting some on my '99 30th WS-6 and
will I need to have a shop put them on or can I do it?
Is there a web site that show you how to swap them?
Is there a web site also that you know that shows you how
to change your rotors from stock to cross-drilled slotted?
Just the rotors,I'm not changing the pads on the car either.
Anthony
Anthony
Re: Eibach Progressive springs
Does anyone have their car lowered with progressive rate springs?
I would like to see some TA pics.with some. Does anyone have the info.
on the changeover of stock rotors to cross-drilled slotted rotors?
irotrs.com make rotors that fit stock sizing that are cross-drilled and slotted. About the springs I dont have any pics but you can definitely do it yourself. The rear springs: Just undo your bottom shock bolts and jack the car up in front of the axle. The back springs should basically fall out. The front ones I just used a compressor to get them out while they are on the strut. The put your new ones on and compress them and put em back in. Any questions during just email me joshp01@email.com Hope this helps a little
carguyshu
01-22-2017 11:19 AM
12-01-2014 08:08 AM
