Eibach Springs + Long Headers
Location: San Juan Puerto Rico, Look it up it's in the Caribean
Hey, Guys
I was planning in buy the Eibach Springs but I want to know if they would low my car to much and then hit in every stop bump in addition I have long headers. I will appreciate any advice.
Thanks !
Thanks !
Re: Eibach Springs + Long Headers
For those who care his car looks to be a 93-96 model...
Anyways I've got a 96 with the small eibach drop and long tubes and occasionally they scrape something. Carful driving is the way but it can be done without any major issues. the 2 inch drop gets to be a pain in DD IMO.
If you gotta do springs/long tubes, you must get the right brands. Pacesetter long tubes are one of the better ones for clearence. I think those eibach springs (1.3" advertised) might drop you a little too much. Try maybe hotchkis or BMR (1" or so). I have hotchkis and pacesetter long tubes and I'm fine. Just gotta b careful over speedbumps and potholes etc.
EDIT: Just noticed you have hooker... Dropping with hookers is not a great idea. If you are goign to do it, definatly get the 1" drop springs. Not Eibach.
so pacesetters r the best way to go for clearence?.....im thinking about a 1.25inch drop would the pacesetters be fine?......also their are alot of crappy roads in my city
abso..
Im dropped on eibachs...and im sitting on C6 wheels...the lts only scrape at the y-pipe...and even before that..it hits at the oil pan. my pan is dented like crazy...but its a lot cheaper to replace than lts...
Originally Posted by CamaroRacing12
so u think i'd be ok with a 1.25inch drop? with pacesetter long tubes?
GnarlyZ28- THat is awesome clearance! !!!!
w/ my SLP LT's, Cats and Y... my sh*t sits about an inch and a half off the ground!
my clearance is terrible.
I ahve the Eibach pro kit and I have major clearance issues w/ the SLP kit...
I scrape on the dang fuel fill caps in the ground at the gas station! THe small ones!
I actuall have eibach sportlines and hoooker LT's with a 2.5" x-pipe and true duals. You just have to drive carefull there are some driveways that i cant go in though because i dont have enough clerance in the center. This is not a daily driver however, if it yours i would not go any lower that 1.25".
Scott
Scott
not a daily driver...but a bit more than a weekend car. ill be ok. im getting used to the clearance. i have to come to a complete stop and crawl over all forms of bumps. grrr
