endlinks and bushing
Re: endlinks and bushing
The 21mm bar will add about 188% roll stiffness if I remember right, so there will be almost double the roll resistance that you had before in the rear. Be careful though, roll resistance in the rear can cause the backend to slide out very easily. You might want to stay with the stock rear bar, like I have. I would recommend a 35mm front bar though. HUGE difference over stock.
Dan
Dan
96SilverRam
11-20-2016 11:19 AM
sleeperZ96BT
09-09-2015 08:28 AM
BLK1997Z28
05-01-2015 12:23 PM
