Is this everything for LS1 brake conversion? (pic)
Re: Is this everything for LS1 brake conversion? (pic)
It looks like you are missing the caliper mounting bracket. Here you can see it in one of rlax31's pics. http://www.radford.edu/~rvandenhe/Pi...acket%202.html. I've heard you can make the LT1 brake lines work but i've never done it. I reused the stock LS1 lines.
On my 95 I reused my LT1 lines, I made 2 brackets about an inch and a half long, and unbolted the line from the frame and used the bracket to hold the line out. Worked perfectly.
I'll prob get stainless lines and I already got some hawk pads. I just wanted to make sure I had all the LS1 parts I need.
Where can I get that caliper mounting bracket?
It looks like you have the right spindles/knuckles. Here is a pic another one of rlax31's. You should look at his pics. http://www.radford.edu/~rvandenhe/Pi...0knuckles.html
As for the caliper mount i would try ebay or a salvage yard.
You have the caliper mount bracket, it's the cage that the caliper mounts to and it holds the pads in place. The back of it has two mounting lugs that bolt to the spindle.
I recently installed powerslot rotors front and rear with hawk pads and upgraded to C5 13" rotors up front and braided brake lines on all four corners.
OH MY GOD!!! The car practically stops before you hit the pedal. HUGE difference.
Originally Posted by Z95m6
I was wrong it does look like you have the caliper mount bracket. Your is just so dirty i blends in.
His aren't dirty. How can you not see those. lol.
http://www.radford.edu/~rvandenhe/Pi...e%20setup.html
or mine which the mount is painted black and the caliper is red. I would post a pic but you can't really see them to well in the ZO6's.
I guess because i'm use to looking at clean painted ones like these.
Eitherway his picture even if they're dirty (on a clean light color carpet) are noticeable.
Right, that's funny since those mounting brackets in the picture you posted are not painted.
I was wrong and admitted it. Don't be hating because you got a stock, fugly azz firebird.
His are clean, mine are painted.
The age group of this board has definatly gone down since I had my 94 z. *sigh*
