Failed inspection. Need to replace right front hub... How?
Re: Failed inspection. Need to replace right front hub... How?
Click on the red link in Shoebox's post on the old thread you raised from the dead:
https://www.camaroz28.com/forums/sho...d.php?t=214844
Raise and support vehicle, remove tire/wheel assembly, unbolt caliper, remove pad bracket (98-02), slide off rotor, disconnect abs wires, unbolt hub and bearing assembly. Reverse removal to install.
10-31-2016 11:09 AM
fpete1992
12-11-2014 03:51 PM
