Few Suspension Questions:
1. Where can I order a good "rag joint" bushing
2. Where can I buy energy suspension bushing for the upper and lower control arm?
3. I need a better explanation of the ball joint, and what is involved in maintenance.
Its a little long winded...
Thanks guys...
Thanks guys...
Re: Few Suspension Questions:
1) why do you need a new rag-joint? if it's bad, typically that's just a factory or typical parts store replacement.
2) www.summitracing.com www.jegs.com
3) Ball joints connect the A-arms to the Spindles; they normally are either good or bad; they should require no maintance except to grease them through the fittings once in a while.
When they fail they are loose, if the ones on your car are solid and only rotate/swivel and aren't loose, then they are fine.
