find ABS sensor ? z28 1994
Can someone help me and explain where I can find ABS sensor near the wheels , The ABS lamps are shining and I need to start see where the problems is, any ideas more I should look after
Jonas / Sweden
Jonas / Sweden
Re: find ABS sensor ? z28 1994
A sensor problem will only light the ABS INOP light AFTER you start to roll. If the light is on before you even start to move, it's something else.
You need to scan it to get the code to even have 1/2 a chance to fix it.
Incidentally, the center brake light will make the cruise control non functional and also light the ABS INOP all the time. Check the brake light.
For reference, your front ABS sensors are in the rear of the wheel hubs and the rear one is in the top center of the rear end housing.
07-04-2005 05:00 PM
