firehawk springs
firehawk springs
This may seem like a silly question but will the Firehawk springs from a 96-97 or 00-02 fit on a 97 z28? I heard/read that they lower the car about 3/4 of an inch. Is this true?
Yes, they will fit, but the question is what springs exactly are you looking at? The base Firehawk/SS springs are exactly the same as a stock Z28/Formula. For 97, the Level II suspension package has the upgraded parts, which includes variable rate springs that lower the car about .5-.75". Combine these with a good shock (Koni, Bilstein HD) and you have a very good handling suspension. Put them with the SLP Bilsteins and you have a good compromise suspension that is better than stock but still gives a very good ride.
Hey thanks man!! The ones I saw were the from the level II suspension. I saw them on slponline. I think I might have to scoop them up!!!! I probably be going with the bilstein HDs.
Will I have to have the HD revalved? Is that really necessary when lowereing a f-body.
Catmaigne
07-14-2015 05:17 PM
