front brake slide pins rattle??
Front end rattle has been narrowed down to my front calipers rattling. I think it is the slide pins/bolts worn out? Anyone have a similar rattle and did they fix with new slide pins/bolts??
Don't the slide pins ride inside a channel that has 2 recesses for 2 o-rings per pin? It's been a while since I did the front brakes... I'd replace the o-rings first and use silicon grease on 'em if so.
Doug
Doug
Magenta_Hearts
03-29-2017 08:54 PM
Hurin
12-13-2014 07:38 PM
07-04-2005 05:00 PM
