Front QA1 HALs w/ V6 springs?
I'm currently using V6 Camaro springs up front on my 96 Z28, and I'll be purchasing QA1 HALs very shortly. Are any modifications necessary to use the V6 springs in conjunction with the HALs? Do I need to get the "spring cup" that BMR sells in order for the parts to work together, or should it be fine?
Re: Front QA1 HALs w/ V6 springs?
You either need the BMR spring cup, or you can modify your stock seats using this diagram:
http://members.aol.com/InjuneerZZ/images/sprgseat.gif
10-31-2016 11:09 AM
