Fuel lines and Double Diamond sfc
I have a set of KB sfc and was wondering were you put your fuel lines after you install these? Do you just leave them hanging? Also how many of you had to elongate the front crossmember mounting bolt to get them to fit? Thanks for any info......John
Re: Fuel lines and Double Diamond sfc
I left the fuel lines alone and in the stock location. -I just shielded them with a sheet of aluminum while I welded. They are between the KBDD's and the Floorpan/Frame now, and protected from road debris. I did buy botls that were 5mm longer for the font crossmember mounting bolts. The old ones worked, but I didn't feel they had enough contact area.
-Justin
-Justin
Thanks guys. I bought my SFC about five years ago. I finally decided to put them on and installing the new stroker motor. I did fit them up and I was looking at the directions for the fuel lines, when I noticed at the top of the instructions they are for a convertible. They fit mine so I wonder what is the difference? Any when else know anything about this? Thanks again...John
10-31-2016 11:09 AM
87Aerocoupe
03-20-2015 01:23 AM
07-04-2005 05:00 PM
