full alinment cost?
Re: full alinment cost?
It should be less than $100, easily -but if I say the shop I go to charges $1, are you going to travel 5 states away to come here?
Why not call around and find out?
Get 3 or more quotes to make sure you're not getting jerked around, and get 'er done!
Casper?? That's a new one! Must be the inward tilt of the tire on the wheel....
Sorry...... anyway, depends on the hourly labor rates of the shop. Some give a flat rate for alignments, the shop I used to work at was 79$... Anything over could charge by the hourly rate... Why do you need all three angles re-aligned?? Usually it tends to be just Toe... "set the toe and go"
Future referance.....Toe, Caster and Camber..... Not busting your *****, just letting ya know....
F'n1996Z28SS
08-23-2023 11:19 PM
NewsBot
12-17-2014 02:50 PM
