Green Grease
Green Grease
Anyone ever use this product? I need a synthetic lube for my poly bushings. I know everyone recommends Super Lube synthetic grease, but it's impossible to find it around here. I can order it online, but can't justify paying nearly $20 to have it shipped to me.
This "Green Grease" sounds pretty good. It's waterproof, rated for marine applications, and rated M2 - W.P. I think it's petroleum free... Here's the specs. on it:
NLGI .................................................. .......................................2
Unworked Penetration 25°C (77°F) D217...................... 280 / 310
Worked Penetration 25°C (77°F) D217 ......................... 285 / 315
Dropping Point 290°C (554°F) D566.................................. 554°F
Water Washout Test D1264............................................. ....Pass
Rust Test D1743 .................................................. ..........Pass #1
Corrosion Test D130.............................................. ..............Pass
Timken OK Load lbs D2509............................................. ........80
Four Ball EP Test Weld Load kg D2956........................... 800kg+
Four Ball Wear Scar mm D2266 ......................................0.0 mm
Base Fluid Viscosity CST 40°C (104°F) .................................920
Base Fluid Viscosity CST 100°C (212°F) .................................58
Viscosity Index .................................................. ....................120
Lubricating Solids .................................................. ..........Present
EP Additives......................................... ...........................Present
Synthetic Polymers.......................................... ................Present
Operating Temperature Range .............................-20°F to 500°
What do you think? Will it work just as well? I found it an Andvance Auto Parts in my neighborhood.
http://www.greengrease.net
NewsBot
09-30-2015 04:20 PM
30th Anniv Z28
08-01-2015 10:39 AM
