Ground Control to help lower my 4x4 camaro back to stock, but for dragging?
Alright ever since I put the 9" moser rear end and removed quite a bit of weight, my car just sits way to high. So I need to lower it back to stock and I was thinking of using Ground Control to do this, but will there springs be worth a crap for launching since mine will basically be just a drag car(very few times on the street). If so what spring lbs should I get from front to back. Or is coilovers in the rear the only best way. I will be eventually buying some adjustable shocks in the back if I go with Ground Control.
Brandon Wittmer
12-03-2014 09:28 PM
07-04-2005 05:00 PM
