ground controll or sportlines
im torn in this deciion is the ground controll that muh better for the price difference? i have 18 inch chrome cobra r wheels and oviously need some springs...any help would be great thanks guys
Re: ground controll or sportlines
It would depend on what your goals are. If you just want that slammed look then go with the sportlines. If its handling that you are after, then I would say go with the coil overs. Spring rate for the sportlines are a bit soft for serious cornering.
Yes, ground control is that much better. As previously mentioned, sportlines do not have enough spring for the amount that they lower the car. Go with the GC (and also seriously consider replacing the stock shocks while you are at it). Good luck.
