Hal QA1 coilover Good or Not worth it
Re: Hal QA1 coilover Good or Not worth it
Do you mean the standard QA1/HAL coil-over shocks for the front, the QA1/HAL coil-over conversion for the rear like Spohn sells, or both?
And what kind of car are you talking about.... year?
The QA1's for the 4th Gen are "coil-over" in the front, just like a stock 4th Gen spring/shock coil-over setup. The stock shock has a fixed lower spring seat. The QA1 shock has a threaded body, so the lower spring seat can be moved up and down by adjusting the nut that locates the seat.
The QA1's for the rear are not coil-over and are not adjustable.... no threads on the body. Spohn builds and sells a rear QA1 "coil-over conversion" that allows you to use a QA1 with a threaded barrel and lower spring seat, making the rear ride height adjustable as well.
QA1 front shock compared to stock shock:
![](http://members.aol.com/InjuneerZZ/images/Photos/shk01.jpg)
Threaded body (Shoebox took this one):
![](http://members.aol.com/InjuneerZZ/images/Photos/shk06.jpg)
Spohn QA1 rear coil-over conversion:
http://www.spohn.net/productimages/736_1_big.jpg
Fbodfather
25
06-21-2002 04:12 PM
