Help Appreciated - 01 R&P will not come off!
Hi - Thanks in advance.
I have a 01 z28 LS1. I am trying to replace the Rack & Pinion. I read some posts on the board on how to do it and have the car half apart and I am stuck.
On the drivers side the bolt holding the rack will not clear the oil pan. I have tried jacking the engine and everything I know how to do except taking the engine mount apart which I really do not want to do.
Appreciate any help.
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
Re: Help Appreciated - 01 R&P will not come off!
For the next guy ... finally figured it out. GM did not leave enough clearance to get the drivers side bolt out of the rack & pinion with the engine in. It cut out easy enough with a recip saw. I reinstalled with the nut on top.
