HELP!!!! EradiSpeed + rotors
in the middle of installing baer eradispeed plus rotors in the front. the front caliper guides wont fit properly. THe front rotors are about 1/2" bigger diameter than stock, and the guides wont line up to the bolt holes in the hub. I was told this was a direct replacement. is there a bracket that i am missing or do i have the wrong rotors? help???
any help please...the car is apart, and i really need it back together...still my daily driver and i have work tomorrow.
Re: HELP!!!! EradiSpeed + rotors
When you say "THe front calipers are about 1/2" bigger diameter than stock", do you mean the front "rotor" or "caliper". I'm guessing rotor, since I don't see how you would measure a caliper by its diameter.
Eradispeed + rotors are direct OE fit.
Eradispeed +1 rotors are larger size than OE, but can use the same caliper. The kit should come with some adapters that move the caliper outwards to clear the new rotors. The adapters are what bolts into your spindle.
Where did you get the kit? Used from a friend. If they are the "+ 1" rotors, then you need the adapters.
Here's the page from Baer explaining this:
http://baer.com/cgi-bin/htmlos.exe/0...44352500013820
sleeperZ96BT
09-09-2015 08:28 AM
