Help me identify this
Re: Help me identify this
Originally Posted by Eff
It looks like the flexy brake line that goes form the hard line to the caliper
Those look like a universal -3 hose size with a banjo to J.I.C. fitting hose assembly. They are designed to couple up to something needing a banjo fitting on one end and designed to use a adapter on the J.I.C side to adapt to the proper fitting on the chassis side. If you want to try and adapt these you could try googling for earls fittings to get the proper chassis fitting.
taner
Advanced Tech
11-09-2003 09:30 PM
