HELP... People with Rear QA1 shocks inside!
#31
Re: HELP... People with Rear QA1 shocks inside!
I'm with Rob.... tighten down the top nut/washer until you see the bushings start to get wider. Did you consider recutting the threads with the next size smaller die?
The fronts are the QA1 coil-overs, with the BMR spring seat. The rears are plain shocks. Rear coil-overs would look like this:
Originally Posted by Honda Hunter
Which are these
#32
I think we did overtighten the passenger side one, and then tried to back it off and the nut would not move, so the threads really got messed up bad. There was a lot of resistance and then when we finally started to get it loose, it just kept spinning and not coming off. Im not sure if i could even re-cut them, they are marred up really bad.
Looks like I will have to contact Sean at Speed Engineering to get me another one ASAP...
Sorry HondaHunter... I was just pissed off last night at the whole issue.
10-31-2016 11:09 AM
squarehead
11-21-2014 08:02 PM
slothgrant
08-22-2002 03:01 PM
